Pitchblack's avatar
Pitchblack
Friendly Neighbour
3 years ago
Speed test.
I did a speed test on my network.  Wirelessly my laptop says Download: 610.58 Mbps
Upload: 480.76 Mbps
Ping: 1 MS
Is this a normal result for a home network connection?  I know that doing an ethernet connection would be best but sometimes having it wireless is convenient. I have the 1024 Mbps download plan.
  • tedfroop's avatar
    tedfroop
    Helpful Neighbour
    One thing to always factor in in all network connections is something called Overhead.
    It's housekeeping packets and depending on how clean your WiFi signal is, repeated malformed or damaged packets.  It can be 30% of your connection speed.  Meaning if you get a data rate 70% of whats rated - your good.
  • NFtoBC's avatar
    WiFi is almost always slower due to the technology involved. Have you checked while Ethernet connected?
    • Pitchblack's avatar
      Pitchblack
      Friendly Neighbour
      Yes, I checked using ethernet and it's much more faster.  Just using wireless since having so many cords it's not so manageable.  I was just curious as to the speed and I do have speedtest app.
  • Nighthawk's avatar
    That's good for wireless. That's roughly what I get using wifi 6 when line of sight to the router.
