Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
06-07-2021 01:30 PM
Setup:
- In my living room, I have a Telus T3200M modem/router, which has built-in MoCA and a coaxial cable going into the wall. I have a Boost Wifi base station plugged into this router
- In my family room, I have a coaxial cable going from the wall to a MoCA adapter, which provides ethernet to a Wifi Extender (WEB6000Q). The one ethernet out port on the WEB6000Q provides ethernet to my TV (not OPTIK TV)
Questions:
- Can I use a gigabit switch to provide more ethernet ports than the WEB6000Q comes with? (it comes with only one usable port)
- Can I plug a Boost Wifi base station into that gigabit switch - will it work this way?
- My brother has a spare Boost Wifi station at his house - can I use this or is it permanently tied to his account?
- Can I use another compatible MoCA adapter elsewhere in my house, if I buy one from either Craigslist or Telus, or am I limited to one?
Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-08-2021 09:49 AM
1. Yes
2. Should work
3. Yes, you should be able to use it once set to your network
4. I’m not sufficiently knowledgeable about multiple MOCA endpoints to comment.
Reply
1 REPLY 1
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-08-2021 09:49 AM
1. Yes
2. Should work
Reply
