January
Hi Community,
I recently switched from Shaw to Telus and ran into an issue with my Hikvision NVR setup. Here's my current setup:
Connection Layout:
The issue is that while the Ethernet wall jacks in rooms 1 and 2 provide internet access to devices, the Hikvision NVR connected to Port 3 cannot connect to the internet. With the exact same setup, the Shaw modem worked perfectly, but the Telus Network Access Hub Modem isn’t allowing the NVR to connect.
Observations:
Questions:
I’d appreciate any guidance or troubleshooting steps you can share. I’ve already contacted Telus support, but I haven’t been able to resolve the issue yet.
Thanks in advance for your help!
This post has a similar issue, but I did not quite understand the solution in this post.
https://forum.telus.com/t5/Internet-Home-Phone/NVR-TELUS-Modem-amp-HIK-CONNECT/m-p/116928#M28665
