04-02-2020 05:46 PM
I am able to view the devices using wifi on either the My Telus Wifi app or through the admin settings.
However, I would like to be able to see how much bandwidth each individual device is using. Is there any way I can do that?
04-02-2020 06:38 PM
There currently is not a way to do that with the current hardware / software. Routers with that ability are not common.
04-02-2020 06:38 PM
