EVS's avatar
EVS
12 months ago
GoogleNest devices and Boost 6
Recently got a Boost 6 and Boost 6E Mini. Having issues connecting my Google Minis, Google Nest doorcam and Nest smoke detectors to the new Telus setup. They worked perfectly with my previous T3200 modem and Boost modules. Anyone experience the same and what was the solution?
1 Reply
  • TELUS_Support's avatar
    Here are some things you can try.
    1. Some devices have trouble with combined 2.4GHz and 5GHz networks. Log in to your TELUS My Wi-Fi app or web portal, and try separating the bands by creating a dedicated 2.4GHz network.
    2. Forget the network on your Google devices and reconnect them to the new network, ensuring you’re using the correct Wi-Fi band.
    3. Verify that the firmware on your Boost 6 and Boost 6E Mini is up to date. You can update it through the My TELUS app or by rebooting the devices.
    4. For the Google Minis, Nest Doorcam, and Smoke Detectors, a factory reset may help them recognize the new Wi-Fi setup.
