Ethernet cable connection
Cnivany
In order to have a wired Wi-Fi connection, can I connect a cable to this unit or does it have to be to my Telus Wi-Fi hub?
1 REPLY 1
Hey @Cnivany - you need to connect your ethernet cable to the Wi-Fi hub
If our reply solved your issue, please click on "Accept as Solution" to help others in the community.
