2 Public IP Addresses With Fibre 1Gb & 1.5Gb
Ducs_Of_Hazzard
Hi There!
Just wondering if you can still put a switch directly after your Fibre Connection and then connect the Telus Router (For their other services Optik TV & Home Phone) as well as your Own Third Party Router (For your home private & guest networks) to the switch? Thus running 2 completely separate networks.
Thanks In Advance!
2 REPLIES 2
AFAIK, yes you can.
Thanks NFtoBC!
Correct me if I'm wrong but it seems that the Fibre -> Switch -> Third Party Router & Telus Router is the only way you can still run a more robust home network while being able to subscribe to the Optik TV  & Home Phone Services and not have issues (i.e. Disconnects).  That is if your Third Party Router isn't "Multicast" capable.
Thanks
