jg3588's avatar
jg3588
4 years ago
Solved
Do you need WiFi for all SmartHome devices to work?
If I've got the control panel, and several sensors (door, motion, CO2, smoke, flood, glass), do I need WiFi to make them work? I understand I would likely need WiFi to be able to control/monitor the systems from my phone, but what if I am getting the security system set up before the WiFi. Will someone (Telus?) be alerted in some way if any of the items are triggered? Can I still arm the home from the control panel itself? Thanks!
  • Disclaimer, although I work for TELUS, I do not specialize in the Smart Home Security department. I'll still do my best though to answer what I can. You are also more than welcome to call TELUS SmartHome Technical Support at: 1-855-255-8828
    The official statement for your question - Source
    Service eligibility - To use TELUS SmartHome Security products, you’ll need high speed internet service to support outdoor camera use and to be within the TELUS Mobility HSPA coverage area.
    My recommendation: You should first have TELUS Internet in your home before installing TELUS SmartHome Security.
    Deeper Dive
    The TELUS Smart Home Security Suite uses a combination of wireless technologies to work. Some use WiFi, cellular data, and or Z-Wave. Most of them use the wireless technology called Z-Wave (not WiFi).
    • If a sensor or device is only running via batteries only, its usually using Z-Wave.
    • If a sensor or device is running via wall power or 120v it is likely using WiFi.
    Although the devices you mentioned will still work without WiFi, you will loose some of the functionality on your phone, but the actual devices such as smoke alarm will still make sound if their is smoke. The details of the lost functionality however I am not positive on.
    Z-Wave Devices (Do not require WiFi)
    • Smart lightbulb
    • Smart plug (appliance or dimmer)
    • Smart door lock
    • Z-wave repeater
    • Smart garage controller
    • Smart thermostat
    • Door/Window Sensor
    • Motion Sensor
    • CO2 Sensor
    • Smoke Sensor
    • Flood Sensor
    • Glass Break Sensor
    Wi-Fi Devices
    • All camera versions
    • Panel
    I hope that helps! 🙂
  • BrandonT's avatar
    BrandonT
    Deeper Dive
    • Smart lightbulb
    • Smart door lock
    • Z-wave repeater
    • Smart thermostat
    • Motion Sensor
    • CO2 Sensor
    • Smoke Sensor
    • Flood Sensor
    Wi-Fi Devices
    • Panel
  • NFtoBC's avatar
    To my knowledge, you need Wi-Fi to properly set up the security system. While it has cellular backup, and some of the devices are Bluetooth, others connect via Wi-Fi.
