dnord
2 years agoFriendly Neighbour
Using old 3200M as second wifi network.
2 years agoThe Boost would go in any of the other LAN ports on the NAH. There are 4 LAN ports plus the 10G port on the NAH.
dnord
Thank you for all your help. I enabled port 1 bridge on the NAH. plugged old T3200M into port1. The boost works as normal plugged into any other port.
Unfortunately it does not work. it sets up a wifi network as normal but does not get an internet connection.
I'm going to try a store bought generic wifi router in port 1 and see if that works.
