Pesi
4 years agoFriendly Neighbour
Upload speed way too slow
I just tested my upload speed with and without my VPN turned on, using speedtest.net With VPN turned off - upload speed was 175 Mbps With VPN turned on - upload speed was just 3.65 Mbps! Is this n...
FuzzyLogic
4 years agoOnce VPN is enabled internet traffic will be routed through that VPN service. This points to an issue with their routing and not Telus.
Pesi
It is a Norton 360 VPN that was installed by Telus itself - is that significant?
- FuzzyLogic4 years ago
A different VPN MAY give you better results. Do you need to be using a VPN? This may help answer that question:
