ArneSalvesen
7 years agoNeighbour
6 years agoThe Arcadyan router is Telus supplied. Given the issues you are having, you could ask for a tech visit (to your driveway) and an exchange of routers.
adrockwe
6 years agoHelpful Neighbour
- NFtoBC6 years ago
- NFtoBC6 years ago
- NFtoBC6 years ago
