ArneSalvesen
7 years agoNeighbour
Powderjockey
6 years agoAdvocate
Yes, I'm using the T3200M as well. most of my devices are connected to it instead of the Boost as there seemed to be too many problems staying connected. I was thinking of changing routers as well.
I was thinking of going to this one, https://www.staples.ca/products/317890-en-asus-rt-ac68u-dual-band-ac1900-wi-fi-gigabit-router as I've got one at work and it just flat out works.
BC_EZ
6 years agoOrganizer
- NFtoBC6 years ago
- NFtoBC6 years ago
- NFtoBC6 years ago
- Nighthawk6 years ago
- BC_EZ6 years agoOrganizer
- NFtoBC6 years ago
- NFtoBC6 years ago
