ArneSalvesen
7 years agoNeighbour
Hogan
7 years agoOrganizer
This is interesting. My Telus wifi was excellent until I bundled everything & I got Optilk TV. Since then for some strange reason, only with my sons & mi=y iPhone do we have trouble with Wifi. Often/all the time I have to either turn the wifi off/on or change the network to get it to connect. Then it works foe=r awhile. N=But then same old, same old No problems with the TV's, laptops anything. Just with the iphones and ipad to a degree. So I went ahead & got the boosters which I hooked yup but then unhooked cause I didn't want to have to sign into 15 or so devices (btw, do I have to connect to the booster on all my devices or can I keep some/any/all connect to the 5f=g, or 2.4 network even while the booster is hooked in & powered up?).
So I think it must be something quirky about Apple products & the Optk TV modem.
7 years agoYes, you can leave whichever devices you wish on the T3200M router.
You could also add the other devices to the mesh network over time; just choose an easy to enter password to make it easier.
I recommend hardwiring as many devices as possible, as it builds a more reliable network.
