lmn19
7 months agoOrganizer
Telus 21T - setting default volume higher?
I have a Telus 21T box. It recently did some firmware update after failing a few times, and is at app version 1.25.10.300 and MW 4.5.1-250811. Since then, the volume of the TV is very low. When I sw...
- 7 months ago
Hi all,
Quick tip to set the TELUS TV digital box volume setting to max. From the TELUS remote, hit the microphone key to launchg the voice control feature and say "set volume to max". This will set the box volume setting to max while keeping your remote configuration as is and let you use your TV or audio system volume to control the output volume.
Hope this helps
7 months agoHi lmn19 - I checked with the team and they provided the following guide.
To change the remote control settings to adjust the volume of the TV Digital Box:
1. Press and hold 'Input' and 'Left' on the remote control for 3 seconds.
Green LED on the remote control should be ON
2. Press 'OK' on the remote control
White and green LED on the remote control should alternate twice.
3. Use the volume on the remote control to increase the volume.
To change the remote control back to adjusting the volume of the TV.
4. Press and hold the 'Input' and 'Right' on the remote control for 3 second
5. Press 'OK' on the remote control
Alternatively:
Press the Google Assistant button on the remote control.
Say "Set volume to max"
Please let us know if this helps
