ArneSalvesen
7 years agoNeighbour
Jammer005
7 years agoOrganizer
I’m not sure how to update.
DGO
6 years agoNeighbour
Did this get resolved with the firmware? How did you get the new firmware?
- NFtoBC6 years ago
- NFtoBC6 years ago
- NFtoBC6 years ago
- Nighthawk6 years ago
- BC_EZ6 years agoOrganizer
- NFtoBC6 years ago
- NFtoBC6 years ago
Yes, I'm using the T3200M as well. most of my devices are connected to it instead of the Boost as there seemed to be too many problems staying connected. I was thinking of changing routers as well.
I was thinking of going to this one, https://www.staples.ca/products/317890-en-asus-rt-ac68u-dual-band-ac1900-wi-fi-gigabit-router as I've got one at work and it just flat out works.
So my problem is solved... finally had the T3200M replaced with the Arcadyan, which meshes with the boosts. (Actually replaced it because could not get it to go over 350Mb when I was on 750.) Have not had the dropping issues since. Also seems to better handle the IoT devices that can't jump frequencies.
Anyway - not sure if we confirmed this, but are all of you on T3200s?
Same issue - Apple devices 'forget' the password on Boosts... Interestingly, not all at once. You can move to another corner of the house (where another Boost is working) and connect fine.
So the workaround I have right now:
- T3200M is on a daily reboot schedule - I needed this before the Boosts came into the picture anyway, as the wifi sometimes gets flaky midway through the day. This is still true.
- T3200M SSIDs are both (2.4, 5) hidden, and Smart Steering is off. Need this for older IoT devices, and for a backup when the main (Boost) wifi fails. It's often better, but as I said, can be flaky too.
- 2 of my 4 Boosts (I blame the ductwork in the house for the dead zones) are now on daily reboots (cheap mechanical timers). We'll see if the others eventually need them too.
It's far from perfect, and numerous tech visits didn't help - they seem really resistant to replacing the T3200M. Each time they come by, they reset it, and "prove" to me that its behaving fine. Whatevs.
- WifiFrustration6 years agoNeighbour
My boosters have this update and its all still no good. I get asked to enter my wifi password on Macbook Pro and iPhone XR every day. Telus has no answers for me. Time to switch providers?
I haven't been able to my Boosters to upgrade to the new firmware. Perhaps I will have to call Telus and see if they have a way to push the new firmware to my Boosters.
