Rocky3
2 months agoGuardian
SOUND
I am watching a show, whether live TV, recorded or streaming. The sound volume goes up and down during the show. At times (TV sound 1-100) it will be just right at 10, other times it is 50. This is ...
Rocky3
14 days agoGuardian
- can you confirm set-top box make/model TELUSTV-21T
- is it across all channels? yes across channels we watch
- do you have your set-top box volume set to 15 (ask google assistant to 'set volume to max')? Yes
- Are you using anything other than set-top box to tv and using TV speakers? Not for a while since I thought that was the problem
- Any sound settings you've changed on your TV? No,
I had mentioned turning off surround sound on tuner, that helps a lot. I had this before Telus occurring with shows with/without surround sound and running thru surround tuner would have to switch on/off stereo/surround.
Sound lost/or out of video sync also occurs when show paused/restarted
