mguscott
6 months agoNeighbour
Replacement remote TV Digital Box
hello. Went to the store to get a replacement remote to which they provided a slimline 2 remote which doesn’t work. I need a replacement remote for my digital TV box. How can I order one? tha...
KHR
TELUS Team Member
6 months agoPasting my reply from a previous inquiry. https://forum.telus.com/t5/Home-Services/Replacement-Remote-TV-Digital-Box/m-p/166054
"You should absolutely be able to order a replacement remote from an agent and compatible remotes are NOT available in stores (the Slimline II is a legacy remote that works with legacy equipment and does not have Bluetooth capabilities)...you can use the Google Home mobile app as a remote until you can get a replacement."
mguscott
How do I do that?
- KHR6 months ago
TELUS Team Member
If you scroll down, there is a 'Contact Us' link at the bottom of this page. You'll likely want to call or chat to reach an agent. Be specific about what equipment you need (having the model # of the remote or box, description of the remote, i.e. the one with a Google Assistant button and Netflix and Prime buttons).
