amam
6 years agoOrganizer
I have parental controls set up on my modem. My daughter has figured out a work around. She resets the modem to default then unplugs the printer ethernet cable and plugs it into her laptop. She gets f...
- 6 years ago
Or you could get something similar to a Meraki, which although intended for business, is cloud managed and only works when it connects to the cloud (and it downloads the settings). If you hit reset on a Meraki, it will just get the settings that were in previously....
6 years agoHero
Both good suggestions above. However there is only so much technology can do to address this situation. There is a behavoral factor here that is out of reach to technology.
If you can't move the router to a secure location then perhaps try to physically secure the router at the current location. Maybe something like this would work:
https://www.amazon.ca/Lockabox-Compact-Hygienic-Lockable-Medicines/dp/B01KVKMGBE/ref=sr_1_42
Drill holes for ventilation and cables. Depending on which router you have you may be able to drill holes for the antenns as well but polycarbonate is fairly transparent to WiFi so it may not be needed.
Related Content
New Optik Andriod tv box - Need Fast forward/Rewind & skip ahead on guide….
When watching a pvr’d program I use to be able to fast forward / rewind at 1,2,3,4 speeds. Now I can only skip 30 sec or go back by 10 Sec. I can also hold down the “wheel” and it fast forwards/rewin...Solved5.5KViews2Comments
