wudao2001
4 years agoNeighbour
- 3 years ago
- Logout
- THANKS ANNA!!!
RinSoCal
3 years agoOrganizer
I have the T3200M modem as well; so no LAN port bridging option.
For the past day I haven't noticed any offline instances by doing this:
- Log into modem admin acct
- Select Advanced Setup
- Select DHCP Reservation
- Select MAC address of Redlink Gateway
- Select any of the available IP's
Appears to be working for me, but YMMV.
RinSoCal
Yeaaah, scratch the above. Back to 'normal', poor, connectivity once again after a day of smooth sailing.
- rcruz3 years agoFriendly NeighbourYeah I'm wondering how Dnice40 was able to access the other IP gateway if they had the Wi-Fi Boost 6. Would be nice to know how to do it and be done with this issue once and for all.
- KRC3 years agoFriendly NeighbourHi, have your issue got resolved?
- RinSoCal3 years agoOrganizer
This is oddly unexpected, but I'll take it:
- Up to November 6 - ~6 offline messages in my inbox daily
- November 7 to now - NO offline instances
How are things on your end?
- paulpooco3 years agoOrganizer
I work for TELUS and reported the issue to an article they had at work about compatibility of the different Gateways and different TELUS hardware about 2 week ago or so.
