Kief
2 years agoOrganizer
Port Forwarding - Port not opened
Hi, I'm trying to a host Minecraft server with my ASUS router behind the T3200M modem (provided by Telus) Here's what it looks like: T3200M -> ASUS Zen Wifi -> PC All of these are wired. When I...
2 years agoHero
Kief wrote:I am running from the PC I have been testing on. Doesn't matter because I have another server and a friend to test off my network.
It matters because it explains why it works when you connect that PC to the T3200M.
Kief wrote:DCHP has been set to my own local ip on my router, port has been set to TCP and the default minecraft port.
Assign your Asus router to a fixed (DHCP reserved) IP address on the T3200M
Assign your PC server to a fixed (DHCP reserved) IP address on the Asus router
Port forward like this:
T3200M --- [port forwarded to Asus router IP] ---> Asus Router --- [port forwarded to PC server IP] ---> PC server
I have the same routers and the above is how I set up my security camera server which has been working for many years.
