Betastorm8
1 year agoFriendly Neighbour
Intermittent connectivity issues with MOCA adapter
Hello! for the last two days, I’ve been encountering intermittent connectivity issues with my moca adapter. Before I began having these issues, the setup was working flawlessly for about the last 5 ...
- 1 year ago
One last update:
Had a tech come out this morning and we swapped out the MoCA, we agreed that the adapter was going bad (had this MoCA for the last ~5 years)
Not running into anymore issues.
Thanks everyone who contributed to the thread.
1 year agoHero
Did you have other devices with an Ethernet port? If so try testing whether it's the PC - adapter combination or not. It's also possible your adapter is failing.
- Betastorm81 year agoFriendly Neighbour
Thanks Xray,
The connection just dropped again now.
While it was down, I took out the ethernet cord from my PC and put it into my laptop. It still will not connect.
I then took a ethernet cable and plugged directly into one of the open ports on the modem, connected without issue.
Modem still had a link light for the MoCA on. I'm leaning toward maybe my MoCA is going bad. Will call into support and see if I can have it replaced.
