mark13bc
4 years agoNeighbour
How to help the old lady next door with her Telus email/Gmail/Chromebook
Hello, Sorry in advance for the lengthy post. My next door neighbor is elderly and a Telus internet customer, not tech savvy in the slightest but she can use email and Facebook, which are lif...
DrPacman
4 years agoRockstar
mark13bc Wrote: While it works, of course she has the usual problem of no Google maps, docs, etc. So when she gets emails that contain links to those things she cannot access them.
I think that I would start by logging into the TELUS Gmail interface and hear on over to the setting section. Have a look under the Forwarding and POP/IMAP section and perhaps forward all the email to the New Gmail account that she has all the other various supported services that your looking for.
The other section for Accounts and Imports may help with the alias that the email are sent from.
- mark13bc4 years agoNeighbour
Thank you, Dr. Your solution is one that I had thought of, but was not sure of the proper settings for the "export" and "import" sides. But I can search for help with that. Also, do you think that will work for map links in messages even though the original message was through telus/gmail? I just hesitate to apply this fix if it's not going to work, because everytime I change things I have to teach her the new way.
