RonAKA
5 years agoRockstar
Conversion to PureFibre - What to expect?
I got hounded until I finally agreed to go to PureFibre instead of my bonded modem copper Internet 75 plan. They agreed to maintain my current rates until the contract time expires. I have a T3200M m...
- 5 years ago
RonAKA My move to fiber. An ont (needs 120 outlet ) A 3200 modem ( needs 120 outlet ) hard wired to ont. My phone was moved to fiber and i asked for battery back up ( needs 120 )outlet . The tech will connect tour existing copper to the ont. I asked for the phone to be moved to fiber. Push button phones will work during an outage with backup. The tech will make you existing setup work . Polecat
RonAKA
5 years agoRockstar
The plot thickens. Nobody showed up from Telus to make the connection to fiber. I phoned Telus and ended up on hold for an hour. When I finally got through I told them I was very disappointed in their service. They told me that no appointment had actually been made to connect up the fiber. I told them I wanted to cancel the conversion to fiber. They told me that would be a bad idea as they are disconnecting the copper service. Is this for real? In any case I finally agreed to get converted on a new date.
It is sad to see the level of service that Telus has degenerated to. I will keep my Shaw coax in place, as I see a switch to Shaw in my future.
Dimo-X
Moderator
5 years agoMissing an appointment can definitely be annoying. It's good that they setup a new date, and in the long run the conversion should be a good thing. Hope the new install date is not much longer.
- RonAKA5 years agoRockstar
They did promise a $50 credit to my account for the missed appointment. However, what really upsets me is that they threaten to cut off the copper. It makes me wonder if this is just an intimidation threat? Is someone that depends on copper for a land line phone going to be cut off? I find that hard to believe.
- Kent25 years agoAdvocate
The phone will be moved from copper to fiber. That is what happened when they put fiber in at my house. It works fine with all your old handsets. The copper to my house was pretty much on its last lags
That is interesting. I wonder what they would do if I refused to accept the conversion to fiber? I have a contract for my current setup that goes until April of next year. I guess there is always the option of Shaw...
