JujhaarSekhon
6 years agoAdvocate
Boost wifi (white booster)
Is it fine if I put my white Telus booster beside a tv. I’m going to put it about a meter away from the tv
- 6 years ago
Hi JujhaarSekhon ,
I don't see there being a problem with putting the TELUS boost WiFi beside your TV...IF that booster has a solid blue light indicating it has a good Wi-Fi or Ethernet connection.
- If the color is amber/yellow then you may want to relocate the booster so its closer to your other booster wired to your modem.
- If you notice slower than usual internet speeds, try relocating the booster and see if speeds improve.
TELUS Boost Wi-Fi Quick Starter Guide: Click Here
TELUS Employee & Neighbourhood Volunteer :black_small_square:If you found this helpful, let others know by clicking the ❤️ Like button.
JujhaarSekhon
6 years agoAdvocate
The best I can get is -57 dBM
BrandonT
TELUS Team Member
6 years agoThats great. Nothing to worry about there.
Some TVs may interfere with your booster if close by. This does not appear to be the case for you, but keep that in mind. If you notice internet connection drops randomly, consider moving the booster to a new location.
Related Content
Using Boosters to boost guest & smart device subnets? Or only main network? (white cylinder modem)
Hey all, I have the wifi hub modem from Telus (it's white, shaped like a cylinder), and I've gone through the Admin options to enable both the Guest network and the Smart Device network. I also have ...Solved5.7KViews3Comments
