JujhaarSekhon's avatar
5 years ago
Solved
Boost wifi (white booster)
Is it fine if I put my white Telus booster beside a tv. I’m going to put it about a meter away from the tv
  • BrandonT's avatar
    5 years ago
    Hi JujhaarSekhon ,
    I don't see there being a problem with putting the TELUS boost WiFi beside your TV...IF that booster has a solid blue light indicating it has a good Wi-Fi or Ethernet connection.
    • If the color is amber/yellow then you may want to relocate the booster so its closer to your other booster wired to your modem.
    • If you notice slower than usual internet speeds, try relocating the booster and see if speeds improve.
    TELUS Boost Wi-Fi Quick Starter Guide: Click Here
    TELUS Employee & Neighbourhood Volunteer :black_small_square:If you found this helpful, let others know by clicking the ❤️ Like button.
