JujhaarSekhon
5 years agoAdvocate
Boost wifi (white booster)
Is it fine if I put my white Telus booster beside a tv. I’m going to put it about a meter away from the tv
- 5 years ago
Hi JujhaarSekhon ,
I don't see there being a problem with putting the TELUS boost WiFi beside your TV...IF that booster has a solid blue light indicating it has a good Wi-Fi or Ethernet connection.
- If the color is amber/yellow then you may want to relocate the booster so its closer to your other booster wired to your modem.
- If you notice slower than usual internet speeds, try relocating the booster and see if speeds improve.
TELUS Boost Wi-Fi Quick Starter Guide: Click Here
TELUS Employee & Neighbourhood Volunteer :black_small_square:If you found this helpful, let others know by clicking the ❤️ Like button.
BrandonT
TELUS Team Member
5 years agoHi JujhaarSekhon ,
- JujhaarSekhon5 years agoAdvocateI put my second booster in a room and it has a signal strength of -60. Is that good?
- BrandonT5 years ago
TELUS Team Member
-60 dBM is good.
If you wanted to fiddle and see if you can get closer to -50 dBM you can try moving your booster to a different location where there booster is closer to the modem, and where there are less walls/obstacles.
Signal Strength Required for -30 dBm Max achievable signal strength. The client can only be a few feet from the AP to achieve this. Not typical or desirable in the real world. N/A -67 dBm Minimum signal strength for applications that require very reliable, timely packet delivery. VoIP/VoWiFi, streaming video -70 dBm Minimum signal strength for reliable packet delivery. Email, web -80 dBm Minimum signal strength for basic connectivity. Packet delivery may be unreliable. N/A -90 dBm Approaching or drowning in the noise floor. Any functionality is highly unlikely. N/A TELUS Employee & Neighbourhood Volunteer :black_small_square:If you found this helpful, let others know by clicking the ❤️ Like button.
- JujhaarSekhon5 years agoAdvocateIs the second booster connected to the first booster?
Related Content
Using Boosters to boost guest & smart device subnets? Or only main network? (white cylinder modem)
Hey all, I have the wifi hub modem from Telus (it's white, shaped like a cylinder), and I've gone through the Admin options to enable both the Guest network and the Smart Device network. I also have ...Solved5.8KViews3Comments
