YvrTown
4 years agoFriendly Neighbour
Another "Why am I not getting 1.5 Gig speed?" question
Hi awesome internet friends. Just accepted increase to 1.5 Gig service, and agent said that he verified my equipment and no changes would be necessary for me to get the new speed. (Which, I shou...
- 4 years ago
YvrTown Wrote: There is no way I am going to get anything above 940Mbps as long as I have that **bleep** T3200, right?
You are indeed correct... The T3200M is equipped with a 1Gbps WAN port and 4x 1gbps LAN ports. Now at very best you can theoretically receive 1.25Gbps throughput on the WAN port in a lab setting, however you are very correct that the best single connection on this type of hardware and connecting will be a max of 940Mbps.
Now, if your Telus connection is provisioned at 1.5gbps, you may if all the additional hardware is capable of the speed achieve the advertised throughput utilizing the current offerings from Telus of either the Arcadyan NH20A Router, or the less utilized Nokia XS-250X-A (Seems to reserved for business installations)
I would contact Telus and see if they would be willing to upgrade your supplied hardware... Cheers...
DrPacman
4 years agoRockstar
- YvrTown4 years agoFriendly Neighbour
Thank you so much for validating.
Is there a way I can confirm that my connection has been provisioned to the 1.5 service? For example, somewhere in the router settings page?
- DrPacman4 years agoRockstar
YvrTown Can confirm that my connection has been provisioned to the 1.5 service?
I believe the best you might see in the T3200M interfaces might be the 1Gbps as that is what that era of hardware was designed to recognize.
Now, your Telus account information under the MyTelus interface will indeed confirm just what package you curranty have assigned to your account. As well if you look under the billing section at the very bottom of the various summaries you'll see a link listed as "View your agreement(s)" That will show full terms and discounts associated with your account.
BTW, when you signed up for the increase in speed, I'm guessing the the Telus rep told you that with the hardware configuration you current have i.e.. the T3200M etc. that the way to achieve the 1.5Gbps download speed would be having multiple sessions downloading at the same time making a total aggregate download speed of the 1.5Gbps.
Personally, I'd stick with the 1Gbps product, It's cheaper, and far less hassle to deploy. i.e. no specialized addition hardware ( faster NIC cards, Switches etc.) or costs.
Thanks again.
The rep told me the equipment I have is capable of the 1.5Gbps, but did not clarify beyond that.
Based on our exchange here, I just spoke to another rep who suggested that both the SFP module and T3200 have to be switched out. So, I have an appointment with a tech in a few weeks.
I am actually only paying $4 more for the speed, and my laptop and phone are both capable of the 1.5Gbps speeds.
So - problem solved.
