DrPacman
3 years agoRockstar
frankw
3 years agoOrganizer
I'm satisfied with the white trashcan router or "Hub" as Telus calls it, made by Arcadyan, and it works fine for me. Getting about 175 Mbps up/down on a ethernet connection or Wi-fi. Using an iPad 7 or 9 or iPhone 8 on WiFi, or wired connection to a 2011 Mac Mini, Telus PVR, 2 Sony TVs, and 2 Apple TV 4K boxes. Usually only using 2 or 3 devices at once, single person household, only use about 200 GB data per month.
The Hub is in the centre of my house in a ground floor closet and is connected there direct to fibre. The Telus technician was OK with letting me get dirty pulling the fibre cable 50 feet in from the garage through the house crawl space to the closet (Telus techs don't like or may not be allowed to go into dusty dark places, but I don't mind).
A Telus PVR and secondary non-PVR box for TVs are connected and one is running all day. There are two 1Gbps ethernet switches connected to the Hub and located in 2 rooms where various devices are connected. I would be interested in trying 1 Gbps from Telus but 180 Mbps is all I need for now.
ab_lostboy
3 years agoNeighbour
Seeing how the device itself is designed to handle the 1.5+Gb speeds (and thats where people have issues) I'd say your experience running the device at .18gb speeds isn't representational. Based on the speeds you're getting, a router from 2012 would give you similar service.
- frankw3 years agoOrganizer
No doubt the white Telus Hub aka Arcadyan can deliver a lot more speed than my 175 Mbps. My Telus account is what limits me to that speed.
