Shane
3 years agoLeader
Some messages not going through
Greetings,
I found out (by accident) that my friend wasn't receiving some text messages, and sometimes they will receive a single message twice.
I tested it by trying to send this message...
dru
Community Manager
3 years agoHave you had issues with coverage lately? Also, has any other contact described similar issues with you?
Shane
3 years agoLeader
Coverage is bad. I live in Langford (part of Greater Victoria). Signal strength is limited to one bar. No other contact has had similar issues, but I can reproduce the issue. It seems that if there is a link in the message, the entire message gets deleted. So the problem seems to be with Telus and not my device.
- dru3 years ago
Community Manager
Is your contact also with TELUS? I would suggest both users to log a ticket with technical support so that the issue can be traced.
Typically outbound messages don't get stripped of content in the event of filtering; it's removed or blocked at the receiving end.
