Telus-21T freezing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
July
Has anybody had any experiences with the 21T Android TV box freezing up? I've called Telus 3 times already about it, and I'm on my 2nd box already.
IMHO, these 21T boxes are a piece of junk & Telus needs to find another solution.
If you are curious about the Wifi signal strength, it stated that it was "strong" during the setup. Unfortunately, it is not possible for me to run it via "wired" Ethernet (as it is too far away from my booster).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
July
Here are a few additional troubleshooting steps that may help improve the performance of your 21T box:
- Clear Cache: Go to the settings on your Android TV box and clear the cache for the apps that you frequently use. This can sometimes resolve performance issues.
- Software Update: Ensure that your Android TV box has the latest software updates installed. Go to Settings > System > About > System Update.
- Factory Reset: As a last resort, you can perform a factory reset on your Android TV box. This will restore the box to its original settings. Go to Settings > Device Preferences > Reset > Factory Data Reset. Please note that this will erase all your data and settings, so make sure to back up any important information.
- Optimize Network: Since your WiFi signal strength is strong but issues persist, consider using a WiFi extender or a powerline adapter to improve the stability of your connection if running a wired Ethernet is not feasible.
We understand that these steps might be similar to what you've already tried, and if the problem continues, send us a private message.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
July
I was only able to solve this by hard wiring all the TVs in the house with Ethernet. Even my Sony TV which is supported by Telus and runs the Telus TV+ app would constantly drop signal when on WiFi.
