mackenzies's avatar
mackenzies
3 years ago
TV Box Won't Set Up
I received my Telus Digital Box yesterday in the mail. I grabbed it from the mailbox. I followed all instructions. Plugged the box into the TV via HDMI, plugged the box into the wall. The box has a light on, but is not connecting to the tv or pairing with the remote it was sent with. I tried a different HDMI cable, no luck. I tried a different TV, no luck. Tried a different power outlet, still didn't work. I unplugged the box and plugged it back in, still no. Tried to click the "factory reset" button in the back... still didn't work. I think they sent me a faulty box. Can someone please confirm this? I have been on hold for 20 minutes trying to speak to an agent about them sending me a new box...
  • Jadebug's avatar
    Jadebug
    Friendly Neighbour
    Hi
    quick question. My new Telus digital box will not go into deep sleep. The light under the box stays blue even without any activity for more than 4 hours. How do I get rid of the blue light? Thank you
    • Nighthawk's avatar
      Blue is the color when the box is inactive / asleep. White is when it's online and in use.
      • Jadebug's avatar
        Jadebug
        Friendly Neighbour
        Great. Thank you.
        Sent from my iPad
  • You plugged what into the wall? You do have a TelusTV-21T box. Did the techs come out and install internet and modem boxes? I thought it was weird that you get the box in the mail but the rest is installed by a Telus rep. I asked him why he did not bring the box too, He shrugged.
  • KHR's avatar
    KHR
    If you can see the LED lit up, it isn't a power problem. What colour is the light? If it's blue, the box is in standby mode. You can press the glossy round button on the front to wake it up. If the LED is white, the box is powered on and you're likely on a different input, as FuzzyLogic suggested. Grab your TV manufacturer's remote, and press the 'input' or 'source' button until your TV screen indicates that you're on the same HDMI input that the box is plugged into. Not all HDMI cables are created equally - please use the HDMI cable that came in your kit.
    There are full set-up instructions at www.telus.com/telustvsetup
  • FuzzyLogic's avatar
    FuzzyLogic
    Have you checked the HDMI input on the TV? Possibly you have it set to a different input than the box is plugged into.
