Rocky3
9 months agoGuardian
Sound suddenly lost reboot needed
Anyone else getting video and no sound suddenly. Only fix is turn OFF and then ON. Just twice in last week, a new event.
- Rocky3Guardian
The previous post got this
Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied.
WHAT HTML?
- Rocky3Guardian
Correct the highlighted errors and try again.
- Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and send the message when you are satisfied.
But nothing is highlighted. I give up.
- Rocky3Guardian
You have reached the limit for number of private messages that you can send for now. Please try again later.
I sent 2 PM
- Rocky3Guardian
Replied to PM
APP version 1.25.3.300
Android OS 12,API:31
Config version 1742400719
MV version 4.3.1-241022
- Rocky3Guardian
Last night lost sound after fast forwarding. Only turn off and back on made sound work again.
Are we now required to do manual updates, check to see if one is available?
What is the current latest update please and I will check mine
- TELUS_Support
We'll send you a private message since we'll need to access your account to find out more information, thanks.
- TELUS_Support
Hello Rocky3, have you done an update on your device recently? Were you able to contact an agent from our support team regarding this issue?
Related Content
Error code: ERR_PLAYER_P212 . Optik TV suddenly won't broadcast on an older-model TV
My Optik TV box suddenly stopped working correctly with an older-model TV last Tuesday. Every time I try to watch live TV, a recording, or on-demand programs, I get a black screen and the same error...Solved581Views5Comments
