a week ago
When trying to watch a 4K Sports Network hockey game on older digital box, I got the message it could not be shown in 4k. So I tried to cast the game to my Sony Bravia TV from my iPhone 14. All good but the picture lags. And it also lags on straight news channels. What can I do to fix this?
a week ago
Casting will be an issue between your phone and the TV. If both have a good network connection it should work but many TVs, including some expensive ones, have an underpowered CPU in them so casting can be flaky for some models.If it lags when casting non 4K content, I'd suspect the TV as the issue. Try casting from another device if possible just to test it. If you have a laptop, you could connect it directly to the TV with HDMI and stream that way. It's less ideal but may work better since it's a hardwired connection.
a week ago
Thursday
Hi @Briguy
The other solution, since you mention that you have a Sony Bravia TV, would be to download the TELUS TV+ app from the Google Play Store and use the app directly. The TELUS TV+ app for Android TV supports 4K channels.
