- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
December
Why is there no volume on only one show I'm watching on Hayu? I was watching an episode, put it on pause. Came back and hit play, no sound. I went back and tried starting the episode again. No luck. Tried putting on a different show, it had volume. Tried watching through my Fire, same problem. This is bizarre!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
December
Hi there! That does sound unusual. Here are some steps to try and resolve this issue:
- Restart the App: Close the Hayu app completely and reopen it.
- Clear Cache: If you're using a streaming device like Fire Stick, try clearing the app's cache in the settings.
- Check Audio Settings: Ensure that your device's audio settings are correct and not muted or set to a specific audio format (like surround sound).
- Test on a Different Device: If possible, try watching the same episode on another device, such as your phone or computer.
- Update the App: Ensure your Hayu app is up to date with the latest version.
If none of these steps work, it may be a specific issue with that episode. You can contact Hayu's support team to report the problem and check for updates on the episode's availability.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
December
