- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
02-19-2024 12:45 PM
Below are the instructions, except I can no longer find auto update apps??? There are updates from time to time, my current version is 1.23.11.400, I recall that was January, a month ago. I was talked thru doing a manual update, but now cannot find that option.
How to keep your TELUS TV+ app updated on Android TV
- Go to your profile and select Settings> Auto-update apps
- Select Auto-update apps at any time
- Navigate to the Google Play Store from the Android TV home screen
- Select your profile and select Manage apps and games
- Under Updates, select TELUS TV+ and then select Update. If updates for multiple apps are available you can select Update all
- Once the TELUS TV+ app update is complete, select Opento launch the TELUS TV+ app
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-20-2024 10:20 AM - edited 02-20-2024 10:22 AM
Hey @Rocky3 , the last update we had was in January with a backend release (no changes to the version number, it's a firmware update). We have a release coming at the end of Feb, and this one will change the version number.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-29-2024 12:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
02-29-2024 12:56 AM
The February 28th version is 1.24.2.200
