DavePI's avatar
DavePI
Friendly Neighbour
2 years ago
Solved
Panel doing a beeping countdown when Arming Stay
Just now when I went to arm my system for the night, using Arm Stay, the panel started doing a 60 second count down. Usually it only does that countdown when Arm Away.
I haven't changed anything about my system. Is anybody else seeing that issue?
Thanks!
  • I eventually figured out that you can select the "Silent Arming" option to eliminate the audible countdown. This was not required for Arm Stay until about a week ago.
  • Phanthomz's avatar
    Phanthomz
    2 years ago
    How do we stop the keypad arming beep, it never use to do it and it's super annoying when someone comes in late. Is there a way to set it as silent like it use to be without doing it individually every time?
  • I am having the same issue.  Since the last system update my system has an audible countdown when "Arm Stay" is activated.
    I called Telus Home Security and the agent told me that the last update had a bug and this cannot be resolved.
    This is very annoying.  Has anyone had this issue resolved?
  • I complained about this in a new post and was able to get this resolved:
    A technician was able to disable a "delayed arming" setting for arm stay, which has caused the system to arm immediately without an exit countdown. Voila, no more noise from the panel when I arm stay.
  • DavePI's avatar
    DavePI
    Friendly Neighbour
    • DingmanJ's avatar
      DingmanJ
      Ok thank you for the heads up. I will get her to look for that when arming the system. I am away and can’t help other than this and hearing about this change to our alarm system and how it’s waking our girls.
  • TELUS_Support's avatar
    The purpose of the Arm Away 60 second countdown is to basically give you enough time to exit the premises without triggering the alarm.
    • DavePI's avatar
      DavePI
      Friendly Neighbour
      This is NOT the accepted solution. It completely misinterprets the question, and is a completely useless answer.
    • DavePI's avatar
      DavePI
      Friendly Neighbour
      How did this get accepted as the accepted solution? It completely misinterprets the question and provides a useless answer.
      Phanthomz
        Hi Phanthomz - we want to help with this. Please look for a message from us in your inbox
