How do I order a replacement door/window sensor?
alittle35
I just had my side door replaced by a contractor.  Unfortunately, the door sensor went to the dump with the door.  How can I order a replacement, and can I install it myself?  TIA
#SmartHomeSecurity
@TELUS_Support
1 REPLY 1
Hi there @alittle35 - we responded to your message
Need to private message us but don't know how? Check out this step-by-step guide.
