June
If I've got the control panel, and several sensors (door, motion, CO2, smoke, flood, glass), do I need WiFi to make them work? I understand I would likely need WiFi to be able to control/monitor the systems from my phone, but what if I am getting the security system set up before the WiFi. Will someone (Telus?) be alerted in some way if any of the items are triggered? Can I still arm the home from the control panel itself? Thanks!
June
To my knowledge, you need Wi-Fi to properly set up the security system. While it has cellular backup, and some of the devices are Bluetooth, others connect via Wi-Fi.
June
Disclaimer, although I work for TELUS, I do not specialize in the Smart Home Security department. I'll still do my best though to answer what I can. You are also more than welcome to call TELUS SmartHome Technical Support at: 1-855-255-8828
The official statement for your question - Source
Service eligibility - To use TELUS SmartHome Security products, you’ll need high speed internet service to support outdoor camera use and to be within the TELUS Mobility HSPA coverage area.
My recommendation: You should first have TELUS Internet in your home before installing TELUS SmartHome Security.
Deeper Dive
The TELUS Smart Home Security Suite uses a combination of wireless technologies to work. Some use WiFi, cellular data, and or Z-Wave. Most of them use the wireless technology called Z-Wave (not WiFi).
Although the devices you mentioned will still work without WiFi, you will loose some of the functionality on your phone, but the actual devices such as smoke alarm will still make sound if their is smoke. The details of the lost functionality however I am not positive on.
Z-Wave Devices (Do not require WiFi)
Wi-Fi Devices
I hope that helps! 🙂
