February
The NHL Hub channel ( channel 910 in Vancouver ) has not been working correctly since the NHL returned from the All-Star break. For example - right now all 3 of the games on the schedule tonight just show " Pre-Game " even though 2 of the games have already been completed and the 3rd game is about half way through the 3rd period.
February
Hi @BobArthur @Steve7 , we have a fix from our third-party vendor to adjust the guide scheduling. The fix should be released within this week. Thank you for flagging.
February
Can anybody from Telus please respond. As of last night all the games were still showing " Pre-Game " even after they were all completed.
February
February
February
Kate - thank you very much for looking into this.
Steve7 - I agree that A-B ( as well as Kate ) are the most helpful reps on this forum and usually are able to find a solution to any problem.
February
Hi again Kate and Steve7 - it looks like the problem with the NHL Hub channel has now been fixed. Right now I can see the scores and stats from last night's game which I could not do yesterday. Thanks again Kate for looking into the problem and bringing it to the attention of the right people.
February
Perfect! Glad the fix went through so quickly. Thanks again for flagging!
a month ago
Fixed where ?it has not worked here in Edmonton for over two months!!!!
a month ago
I'm in Edmonton and it works fine for me. It's got current stats and schedules. Which teams are you following? Which set model of top box are you using?
a month ago
It has not worked for over two months.i thought it might be the tv , unplugged it and reset the box etc , nothing . Called Telus and reported it to a tech , he did a check while I was on the phone with him .he said that it was a problem with the provider . I have since made 4-5 reports on here and it is still not addressed.. I follow the same team as always , no changes on my end , but it always show the games <but not the scores/updates.
February
Yup - it's definitely fixed. Thanks Kate. 👍
