BobArthur
3 years agoLeader
NHL Hub Channel Not Working Correctly
The NHL Hub channel ( channel 910 in Vancouver ) has not been working correctly since the NHL returned from the All-Star break. For example - right now all 3 of the games on the schedule tonight just...
Eleonoragodwin
2 years agoNeighbour
Fixed where ?it has not worked here in Edmonton for over two months!!!!
2 years agoI'm in Edmonton and it works fine for me. It's got current stats and schedules. Which teams are you following? Which set model of top box are you using?
- Eleonoragodwin2 years agoNeighbour
It has not worked for over two months.i thought it might be the tv , unplugged it and reset the box etc , nothing . Called Telus and reported it to a tech , he did a check while I was on the phone with him .he said that it was a problem with the provider . I have since made 4-5 reports on here and it is still not addressed.. I follow the same team as always , no changes on my end , but it always show the games <but not the scores/updates.
