More Huawei B593 4G LTE Smart Hub problems
mcmuffin91
Friendly Neighbour
I bought this thing i could play games online with friends, on my 360, ps3, and 3ds but when i try to join my friends in games, it doesnt work, im sure its my end since they could play with other friends. I made my 3ds the dmz host but that didnt work, any more fixes? its like a very restrictive network or something
3 ACCEPTED SOLUTIONS
SuperFred
Moderator
Moderator
Hi, can you use it to surf the web on a computer? I don't think wireless keys will provide a strong enough connection for online gaming. I tried once with my 360 and nothing. But the wireless stick works great on my pc.
late reply but it works with my computer and i could play on my 360 with random people on halo but i cant play with specific friends, its like a closed nat or something
Hi, if you can play with random people and not with selected people, I would say that the issue isn't caused by your equipment or network. I suggest you to contact xbox live support. I hope they'll be able to help you.
3 REPLIES 3
SuperFred
Moderator
Moderator
