Can anyone tell me what are the first step to connect my device with my wifi at home, tks!
There's going to be a different method depending on the phone you use.
Here's a link that will walk you through the procedure for your specific device: http://mobility.telus.com/en/BC/International/connecting-to-a-wi-fi-network-while-travelling-outside...
*Don't mind the title, it's the same thing if you're inside Canada
