light phone2
Finfin
I just bought a light phone2. It's supposed to be compatible with Telus 4G.
I can send and receive texts but making phone calls it sometimes works but most times not.
The call seems to get disconnected as soon as someone answers.
What could be the problem?
1 REPLY 1
Guardian
You are not the only one with issues using the Light Phone. This sounds like the same problem.
https://www.reddit.com/r/LightPhone/comments/hp0kst/light_phone_2_sim_issues/
