Alith's avatar
Alith
Organizer
5 years ago
Solved
Smart Hub computer connection light issue
Is the light on the smart hub that indicates a computer connection, supposed to be flashing or a steady on when a PC is hard wired to hub?
  • Steady. It flashes to indicate WPS readiness, amongst other things. The lights on the LAN ports flash to indicate connectivity.
  • NFtoBC's avatar
    • Alith's avatar
      Alith
      Organizer
      On my modem all the lights are steady except the computer one. That one is always flashing.
      Right now my wifi connection works fine but my hard wired does not. I get a check network message when hard wired.
      • xray's avatar
        Hero
        Can you test with a different computer?
        Can you test with a different Ethernet cable?
