Alith
5 years agoOrganizer
Smart Hub computer connection light issue
Is the light on the smart hub that indicates a computer connection, supposed to be flashing or a steady on when a PC is hard wired to hub?
- 5 years ago
Steady. It flashes to indicate WPS readiness, amongst other things. The lights on the LAN ports flash to indicate connectivity.
5 years agoSteady. It flashes to indicate WPS readiness, amongst other things. The lights on the LAN ports flash to indicate connectivity.
- Alith5 years agoOrganizerOn my modem all the lights are steady except the computer one. That one is always flashing.
Right now my wifi connection works fine but my hard wired does not. I get a check network message when hard wired.- xray5 years agoHeroCan you test with a different computer?
Can you test with a different Ethernet cable?- Alith5 years agoOrganizer
I tested with a different ethernet cable and I also tried hard wiring my laptop. Neither made a difference. When I checked the laptop network status and chose ethernet, it had an "unidentified network and no internet" message beside it.
