Will a Cat S41 work on telus?
Funwrecker
I'm thinking of getting a cat S41 phone for the durability, but I would like to know if it will work on telus's systems BEFORE purchasing. I'm not up on how the frequency stuff works, so telling me to look won't help me any.
Thanks .
It should, if the North American variant is purchased.
Telus uses Band 5 and Band 2 for 3G, and Band 4 and Band 29 for LTE
The Cat S41 includes Band 5 and Band 2 on 3G, and Band 4 for LTE. It does not appear to use Band 29, so may drop to 3G in areas where Band 29 is implemented.
1 REPLY 1
