09-15-2015 07:15 PM
I'm looking to buy a Samsung Tab 4 7.0 (wifi + cellular) to use on the Telus network, but there are different models. Which one will work with Telus?
SM-T231
SM-T235
SM-T235Y
SM-T237P
SM-T2397
Those are the ones I've seen for sale. There are probably more. Thanks in advance to anyone who can clear up the confusion!
09-15-2015 08:41 PM
If purchased in Canada any should work. You will want to ensure it uses the following bands:
3G HSPA+ / WCDMA 850/1900
4G LTE 1700/2100
09-15-2015 08:41 PM
4G LTE 1700/2100
