Square credit card readers-compatibility with phones
sandy49-250
I need suggestions for android phones that support the Square credit card readers.  I don't have a fortune to spend on an Iphone.  I would like to purchase with no contract.  Wanting to keep the plan I have.  Any suggestions?
Can you please ask your question through this link? https://squareup.com/help  They will most likely be able to answer your question.
4 REPLIES 4
ET
Rockstar
Good morning @sandy49-250 you might want to have a look at this.https://play.google.com/store/apps/details?id=com.squareup
But I know I need a newer phone, the question is other than an Iphone , what will work with Square.  My current phone is SamsungA885. It is ancient in todays terms.
FS
NEVER SQUARE UP they are the most misleading company ever. Read on the web you will see how bad is their customer service and how deceiving is their tactics.
After accepting your application almost automatically and after you privide them with all the legal document. They wait untill you charge your client almost 6K and then they tell you they refuse your apps because they think you are a fraud. THEY WANT TO HOLD THE MONEY FOR 180 DAYS ... they try this with almost every business.
They are strpped for cash and they are scamming people.
RUN AWAY FROM SQUARE
