11-30-2016 12:41 PM - edited 11-30-2016 01:55 PM
I got a really good deal on a Samsung G S7 Edge locked to Rogers from a friend. I unlocked the phone using an unlock service (Canada GSM Unlock). Once unlocked with the SIM card in the device it worked as expected for a while, however, after some time the device would not allowing me to access data (the network bars were full and showing either LTE+, LTE or 4G service, nothing unexpected). For the device to access data again I would either have to restart the phone or do a reset of the network settings, however, this would only fix the issue temporarily. I called Telus tech support to see if it could be something on Telus's side, however, no luck. The tech advised me to take the phone to a Telus store thinking it might be the device itself.
Doing some of my own research I found that both Rogers and Telus work on the same LTE/LTE+ network bandwidths and that the same phone model is sold by both carriers.
Additionally, I also set the APN setting according to this site (https://apn-canada.gishan.net/settings/1429_3_telus_mobility_apn_settings_for_samsung_galaxy_s7_edge...) and set the Network Operators to "GSM/HSPA (auto-connect)" and it starting working unfortunately only on the 4G network.
I would like to figure out why the device has no data on the Telus LTE/LTE+ network.
Advice or a reason for this would issue would be very much appreciate
Thank you.
11-30-2016 01:15 PM
Some phones report the network as 4G / 4G+, and other phones report the same network as LTE. LTE is a subset of 4G.
11-30-2016 01:58 PM
I didn't know that however, I still have to set the Network Operators to "GSM/HSPA (auto-connect)" for data to work, which would only allow 4G HSPA not LTE.
12-03-2016 01:16 AM
12-03-2016 07:42 AM
When I set the Network mode to "GSM/HSPA/LTE (auto connect)" its shows LTE connection beside the network bar, however, I have no data. Calling and text messaging still works.
12-04-2016 12:45 PM - edited 12-04-2016 12:53 PM
12-05-2016 10:09 AM
Typing that code into the dialer shows:
AP: G935W8VLU2APK3
CP: G935W8VLU2APK3
CSC: G935W8OYA2APK3
If it is incorrect, how do I go about changing it?
