PlayStation Portal won’t connect to Telus Mobile Hotspot from iPhone
Khalilkhan
Hi, I bought the new PlayStation portal and it works great on home wifi but does not work at all on my mobile hotspot from my iPhone. Is there any fix for that?
1 REPLY 1
dru
Community Manager
Community Manager
I'm not sure how popular the PlayStation Portal is but it does seem like a niche use case connecting to a personal hotspot. i can't recommend any official workarounds but I found this link on redditL https://www.reddit.com/r/PlaystationPortal/comments/17yjf3w/playstation_portal_not_connecting_via_mo...
Try and have a look to see if it helps.
